You dont have to use all of the power from the amp, you will have some head room in case you wanted to add diff subs later or whatever...now would that push too much to my speakers and peak them out
The guy that told you that apparently does not know what he is talking about.... Any 2 D4 subs can be wired to 1ohm......can all dvc 4 ohm speakers be wired to 1 ohm load, the guy that I bought these from said that I can't bridge them or wire them to a 1 ohm load because I would cook them I have 2 audiopipe 12 inch subs I am new to all of this so sorry for all the questions
You will be wiring your subs down to 1 ohm so theoretically yes that will be 1000rms in a perfect world. You will have box rise also, it varies from build to build. So like I said earlier, you will not get the full potential out of this amp......now 1 ohm load I will be pushing 1000x1@1 ohm that would be ok wouldn't it because if I wire them together then my rms 750 and peak 1500 so I would be 250 over my rms correct I want to get as much out of these speakers without blowing them in 6 months to a year
