****Helppppppp!!!!!*** Subwoofer Help*****
shadow028
Someone help me please!!! I just connected 3 12" Kicker L'7's with a 2100 watt brutus hifonics amplifer. The first day they were working great, the second day I had to replace the terminal on the subwoofer box, they worked great again for a couple more hours. I did smell like something was burning I turned them off checked the problem seems like my wires that connected from the amp to the box were too weak as they almost melted together. I replaced the wirings now, I can play a couple minutes at a stand still, but once I get to driving it seems like they cut out either immediately or whenever I raise the volume a bit. They seem to work at low levels but cut out as soon as I raise the volume one of the subwoofers even sounds blown or damaged. But at lower levels all 3 of them sound normal, I can even raise the volume and get about a minute of play with them all sounding normal. They are connected in a 2011 Chevy Tahoe if that means anything, I did notice my battery gauge when they hit I have less then 14 when they are off I have more then 14 volts also I noticed the people who installed it did not scratch the metal in my truck in order to ground it to bare metal. Not sure if any of this helps, but please help me figure this out its driving me crazy. I want my sounds back //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Can you explain what you mean "to low"?
If with the three subs you're wired to .33 ohms or even worse, .155, I'm surprised it still makes sound.
Unplug the subs from the amp. Connect a digital voltage meter to the wires. Set it to ohms. Record the number. Touch the leads of the Digital voltage meter together. Subtract that number from the first one. That is what you are wired to.
That number should not be below 1.0
Just another reason why I do my own installs. Some shops just don't know who to trust unless you know someone there.
Back to the problem sand down to bare metal and run either two sub's or buy another.
shadow028
shadow028
Joliet
Boomin_tahoe
