Help !!!!
It doesn't matter if the speaker has wire leads or spring terminals or spade terminals or bolts and nuts... positive is positive is positive and negative is negative is negative... always.
Positive is always on the right when looking at the sub from the rear with the coil terminations at 6 o'clock and, of course, negative is always on the left.
im confused on this direct connect lead wires. hahaha I wish this sub had terminals !!! i dont understand how to take D2 and make it 1 ohm with no terminals? maybe connect them with a wire nut and add another wire with it for the amp?
MK5 Fahrenheit
MK5 Fahrenheit
Plymouth, MN
globalminds_ent
