help?
ok so say i wire the subs together would that run them both at 600 or if i unplugged the one sub would that make the one run at 600
Please clarify what you're asking here. If you just hook one of your subs up to the amp that would be a 4 ohm load, you said the amp does 400 watts at 4 ohms, so the sub would get 400 watts.
ok i think i understand now so my 2 4 ohm subs are parralled together at the amp so that makes it a 2 ohm load a 600w and there are 2 subs so it divides the power to 300w per sub right? so say if i wanted to run 600w to each sub could i do that with this amp? also my subs are in a sealed box would they be better in a ported box?
ok i think i understand now so my 2 4 ohm subs are parralled together at the amp so that makes it a 2 ohm load a 600w and there are 2 subs so it divides the power to 300w per sub right? -- correct
no you cannot - that would require a 1,200 watt amp
if you wanted them louder than a ported box would be better
what size wire are you using to power the amp?
You got it now buddy. 600 rms is about all you can get out of that amp, and yes ported is usually louder.
splwj47
splwj47
Great White North
splwj47
BP1Fanatic
BP1Fanatic
