Help...
also how would i position this stuff in my room?
Ah, the question of imaging. To me, this is the most important aspect of the audio experience. First, you need to spread them out far enough so that you have a decent sound stage. Next, you want to angle the speakers inwards (like toe-in on a car) so that they make an imaginary triangle with you at the middle. MAKE SURE THE TRIANGLE IS ISOSCELES. Otherwise, the image will be biased left or right. What I do (don't flame for nerdness, it's awesome) is I went to office max and bought two of their smallest laser pointers. Depending on the height of the speaker you may have to position it high or low, but either way place it in the middle of the speaker anywhere you can. Turn them on and aim them at your listening location. When the dots merge at where you're sitting (no bias), you have found the spot. Remember, an INCH can make a drastic difference.
ok i think i have all of this down. when porting a sub box should i just do 1 3" round port? also should it be on the same side as the sub? is it basically the same as car audio?
ok i'm pretty sure how this is gonna go. now i gotta decide on a tv //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
how much money do you have to spend? I would try to get a hdtv for the 360..its amazing when its on a decent hdtv
No, I wouldn't do a slot. You will take up so much room making a low tuned port in that small of a box that it may not even be possible. A single 4" port is adequate.
iceteebone
Banned
iceteebone
Michigan
iceteebone
