help with wiring new amp
brybry354
i already have my system correctly hooked up but i intend on switching out the subs for stronger ones and hooking them up to separate amps.
when i hook up my new amp do i need to put a ground in it and hook it up to the 12v battery or will hooking up to just 1 amp be enough after i split the RCA cables?
i already have a ground and power wire leading to the 12v battery on amp #1
my question is do i need to put another ground and wire hooked up to the 12v battery on amp #2 as well?
Yes, each amp will require it's own power, ground, and amp turn on wires. Depending on the existing gauge wire to your battery, you may be able to use a distribution block to split the power to both amps.
brybry354
brybry354
Texas
GearGuy2001
