Help with wiring for amp
Ryknow16
I need some help hooking up the wires to my amp and sub. I had a friend install it for me the first time, but now i just need to put the amp back in my car. I need to know where each wire attaches to on the amp. Its a Pheonix Gold QX180.2.
I need to attach:
-power cable from battery
-wire from cd player
-ground wire
-wire to the sub
these are the possible places to attach:
Power:
-B+
-B-
-R
Speakers:
-L+
-L-
-R+
-R-
please help me!
Plug the wire from the batt to the B+
Plug the Ground to the B-
If its a single sub or single terminal set up.....and a bridged amp plug the negitive into L- and the Pos in R+ or vise versa.......now if its a 2 sub setup with two indepenent speaker wire sets than plug the left sub pos into L+ and left NEg into L- and do the same for the right 1
IF its a mono amp and u have 1 set of wires regardless of howmany subs than u can either plug em both in either L sets or R sets or do like you would if it was bridgable....to be on the safe side id just plug em into 1 set because sum amps dont like it when u externally bridge them like that when they already are bridged internally
when u say wire from cd do u mean the rcas or remote....prolly remote cuz if u couldnt find the rca hookups...well...u shuoldnt be doing this yourself....if it is the remote than that goes into the R
thanx alot jmiller.....its the remote. i found the rcas. that was about the only thing that i knew exactly where it went. i had an idea where most of it went, but wasnt exaclty sure. thanx again
Ryknow16
Ryknow16
BC, Canada
Apoc
