help with what wiring to buy?
recently bought 2 alpine subs 3000w max and i have a 2 channel 6000w amp..lanzarso prollly not even actualy 6000w..anyways was wanting to know what wiring i need? what gauge? how much it will cost? do i need capacitor? etc?
try to buy stuff based on RMS ratings not peak power ratings for a start. Brands like Lanzar, boss, pyramid, pyle, power accoustik really likes using fake bloated numbers to sell to car audio newbies looking for the biggest number possible. The sad truth is the performance is not there at all.
Edit:
This might be the amp your talking about Amazon.com: Customer Reviews: Lanzar VCT2610 6,000-Watt 2-Channel High-Power Mosfet Amplifier This will need 4 gauge wire.
Actual owner's manual specs from another reviewer on amazon
RMS Power @4 Ohms 300 watts x2
THD @4 Ohms 450 watts x2
RMS Power @2 Ohms 600 watts x2
THD @2 Ohms 900 watts x2
Maximum Power Output @2 Ohm 6,000 watts x1
Bridged Power @4ohm 8,000 watts x1
Low Level Impendance Input: 10K Ohms
Low Level Sensitivity Input: 200mV-6V Adjustable
S/N Ratio: 95dB
Channel Separation: 65dB
Chrossover Filters-
Low Pass:40 Hz-150 Hz
High Pass:40 Hz-250 Hz
Bass Boost: 0~+18dB
Sub Sonic Filter:10-100 Hz
Stereo Mode: 2-4 Ohms
Bridged Mode: 4-8 Ohms
Fuse Size: 60A x2
Power Supply Voltage: 14.4V DC Neg. Ground (10.5-16V)
They claim 600 rms per channel at 2 ohms, but i still doubt thats clean power.
The amp will work with your subs even if its only tickling them. If you want to get loud, see if you can return the amp and get something along the lines of Precision Power PPI BK1800.1D Black Ice 1800W Monoblock Class-D Amplifier This amp would do a solid 2000 RMS which is perfect for type Rs. You'll need 0 gauge wire for this amp since its a lot more powerful and requires thicker gauge wire.
conn55255
conn55255
Iowa
mylows10
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
