Help with Wattage on Subs.
Biker
If I have 2 10" subwoffers rated at 600 Watts RMS each with dual 2 ohm voice coils can I wire them together for a total 1 ohm load and send 1200 watts to them?
So to think this thing out I would have to wire one 2 ohm voice coil on one speaker in parallel with the other for a 1 ohm load. But that would leave the other 2 voice coils unused so does that effect how much power they can handle?
If so then would I need to wire the 2 subs with a 2 ohm load and use an amp that can send 1200 watts at 2 ohms. $$$
Biker
Biker
You can't get a 1 ohm load from 2 DVC 2 ohm woofers. yes you need an amp that is 1200 watts @ 2 ohms.
only .5 ohm load, or 4 ohm load.
Thank you very much...... I now understand that having a DVC gives you 2 options for load but both voice coils need to be used. So now the cost of the amp just went up.
Thanks again
Biker
Biker
Biker
Tracy, CA
MikeyB
ThxOne
    May 13, 2026
