Help with wattage and ohms please!
Well i'm not really sure what the sub is i guess. When i previously said 2 ohm i just was reading what it said on the box that the sub and enclosure came in... I guess the actually sub could be 4 ohm, wired to 2 ohm?
My DMM is this below, i took the speakers wires out and turned the setting to 1k ohm and turned the ohm adjuster button all the way to the left, it showed 2 ohms at that, when i turned it to the right it still showed like 1.5 ohms...
Amazon.com: Greenlee AM-6 Analog Multimeter: Home Improvement
The L3 is available in DVC 2Ω and DVC 4Ω, the sub in the enclosure is probably a DVC 4Ω wired in parallel. The only safe way to use that sub with your amp would be to rewire the coils in series for an 8Ω load. If the amp ratings from Sony are correct you will be feeding the sub 370 watts, so when you set the gains the output voltage should be 54.4 VAC.
Can't i just wire it to one channel, and forget the mono deal?
BTW Anyone think it's worth getting my Concept CC-D1200 amp fixed and if so how much would that cost, and i wouldn't know where to take it to get fixed?
So if i wire each coil to its own channel i will get ______? watts
or if i internally wire it to 8 ohms i will get 380 watts?
Wiring each soil to its own channel, or paralleling the coils and running the amp mono will create the same wattage from the amplifier. Bridging an amp simply means halving the mono load between each channel. But wiring each coil separately to its own channel means having to deal with summing the signal to mono pre-amplifier to avoid stereo separation working the coils against each other.
mahosky85
mahosky85
PA
sacsking916
