help with sub wireing
description says dual 2 ohm. so plug in 2 dual 2 ohm subs.
# One-Way, Linear Excursion -Xmax: 18 mm
# Efficiency -SPL 1W/1m: 86.1 dB SPL
# Effective Piston Area -Sd: 480 cm^2
# DC Resistance -Re: 2.8 ohm
# Nominal Impedance -Znom: Dual 4 ohm
# Thermal Power Handling -Pe: 600 W
# Force Factor -Bl: 17.7
# SE12-D4 (SE.12.D4/SE12D4) Re
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
ok i see but i have one more question for ya..... how does it only have one posotive wire and one negative wire coming from the amp????? for 2 subs.. and is it bridged.. my amp is a 2 channel.
oh i saw this?
# Dual Composite 2-piece Cone Rubbertek Foam Surround
# Cast Aluminum Basket
# Tork-Tite Terminal
# 3 ” 4-layer Aluminum Voice Coil
# FEA Optimized Motor Structure
# Triple Stack Magnets
# Progressive Spiders
# Wrap around Rubber Gasket
# SE12-D4 (SE.12.D4/SE12D4) Dimensions:
# SE12 12" Dual 2ohm Subwoofer
im pretty sure there the 2 ohms they are the 2 ohm in the heading and they are 10 dollars less...... uh o allready ordered them.. will it be allright
well i guess when you get them let us know what you ended up with and well let you no how you can wire them.
And if it will be alright //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
jeremy.vaughn
jeremy.vaughn
marion county AL
jeremy.vaughn
vegang
vegang
