help with something that doesn't sound right
SRT8
Hello, a little while ago I installed a Kicker dx250.1 amp and Comp 10 sub on my factory Chrysler MyGig system using the high level speaker inputs of the amp. Problem is, it is extremely boomy at lower volumes, and then you can't hear the sub when cranked up. I know factory units reduce bass at higher volumes to save the speakers, so I guess that is what it's doing. I was going to buy the Kicker bass knob and crank that up with the volume loud, but when I played with the amp gain, you still can't hear the sub when cranked. The sub and amp both get good reviews, so I don't think it's a fault of either. Oh, and I used a 60 hz test tone to set the gain using a multi meter already.
Do I need to add some sort of bass restorer so it doesn't cut the bass signal going to the amp?
you can get OEM interfaces that will correct for factory EQ's. the best versions will add a new volume control and the factory HU is left constant volume. but this requires aftermarket amplifiers for every speaker.
glad you solved the issue.
SRT8
SRT8
Edmonton, AB
keep_hope_alive
vegang
vegang
