Help with simple design
MikeyF
It is what it is
Hey, I needed some help with a simple design. I was wondering if anyone could draw up a box design for a 12" DC LVL 4, tuned to 33hz. The website says it should be 1.5 cubes, but I defiantly thought they would be a bit bigger, like around 3. Would like it for a daily driver. But heres the info for the sub, and any help would be greatly appreciated. Thanks, Mike.
Mounting Depth
6.75"
Mounting Hole Diameter
11"
Motor Width
7.75"
VC Diameter
3"
Magnet Weight
28.5lbs
Sd
494.00 cm²
Vas
66.60 L
Cms
1.95e-04 m/N
Mms
173.08 g
Fs
27.4 Hz
Bl
16.15
Le
4.02 mH
Qms
5.13
Qes
0.42
Qts
0.39
Xmax
23.5 mm
Sensitivity
87.0 dB
Suggested Ported
1.5³ ft
Suggested SPL Ported
2³ ft
130
438
418
MikeyF
It is what it is
MikeyF
Detwat, Michigan
FootlongSam
    Jun 1, 2024
    May 31, 2024
