Help with setting gains on amp
yeah, but thats the highest that i listen too, so do i still set it at my listening volume, or some high number that the headunit will never see
well i thought i knew how to adjust the gains on my amplifiers till i read Sage's post... i didn't know you had to calculate the maximum output of your amplifiers... i thought some amps were overated and others underated, thus putting out different wattages than announced, so what i always did was to put the DMM to my speaker outputs with the test tone at volume 26 (out of 35 from my 9815) and slowly increased the gains till the voltaged wouldnt climb any higher.. than go back a touch and that was it
anyone confirms if what i did was right or wrong plz?
if i really wanted to ghetto it i guess i could just play a tone and crank away till i hear it obviously distorting, then set it back a notch and call it good
This is why im bumping it
As for where you set it at, around 75-80% of max volume is recommendable. I wouldn't do something as low as 20 out of 35. That's around.. what.. 60%?
The highest i listen to is 20, so do i set it at 20, or to something higher even though ill never play it that loud, meaning ill never see full output at my target volume
what you mean by ghetto? many people use this method to adjust gains and it's written on my alpine amplifier manual aswel...
i don't believe they would like people to "ghetto" their amplifiers, do you?
i run alpine everything, ive got some type r cabin speakers in the mixs, hell, if alpine made the wiring, ide probobly buy that too, it seems like a crude method compared to these "special" ways of doing it
so do i tune the amp at my maximum listening volume ( 60% ) , or do higher on the headunit and tune it from a higher spot ( 75 - 80% ) , even though ill never play it that loud, someone said 60% was pretty low to tune the amp too, but its the max that i ever listen too
No matter the number on your head unit the speakers will only play so loud with 40w if you set the gain at 20 or 30 as long as the amp puts out the right voltage the speakers will be the same volume
lower volume the higher you haveot have th gain because the pre-out voltage is lower
Astyl
Car Audio Enthusiast
Astyl
Bedford, NH
Blunt
