fatboyracing
I cant remeber the last time I built a sealed box got a few?
is this the outside measurements of the box or the inside
It says to build the box to .365 cubes sealed
so that would be 10" by 10" by 6.3" right or do you add for the sub
this is for a 8in polk marine speaker going in a boat
these are the specs I have
Parameters MM840SVC
Type 8" (203.2mm)
Frequency response 26-200Hz
Fs (Hz) 35Hz
Re 3.25 Ω
Le 2.3mH
Qms 5.5
Qes 0.7
Qts 0.6
Vas 0.54ft3
Sd 35.65in
Sensitivity 89dB
Oneway/Excursion 3/4"
Voicecoil Diameter 1 1/2"
Mounting depth 4"
Mounting Diameter 7 1/16"
Parameters MM840SVC
Type 8" (203.2mm)
Fs (Hz) 35Hz
Re 3.25 Ω
Le 2.3mH
Qms 5.5
Qes 0.7
Qts 0.6
Vas 0.54ft3
Sd 35.65in
Sensitivity 89dB
Mounting depth 4"
