Help with port dimensions plz
Colossus281
This will be the box I'm building I need help figuring out what size to make my ports to have it tuned two 32hz thanks.
calculating size and port length involves alot of math and most people wont do it for u. i usually go with around 15in2 of port opening area per cubic foot of box volume i think. dont include the volume of the port into the volume of the box. and ummm it would be alot more helpful if u posted what subs your using, and what vehicle, and the total volume in your car that u want to use. and how much power. Box equations
So assuming you are using .75 inch material all around you are starting out with a gross volume of 6.52 cubic feet.
So if you, and if someone could double check my math that would be great, do 2 ports each being 7x5 you will have 70 sq feet of total surface area. Each port will be 20 inches long. I assumed .1 cubic feet of displacement per driver so a total of .3 cubic feet of driver displacement and 1.46 cubic feet of port displacement. Your end result should be a net volume of 4.76 cubic feet, tuned to 32 hz, with 14.7 sq inches of port per cubic foot.
Colossus281
Colossus281
Albuquerque nm
jeremyg1
