I have six new SHURiKEN SK-BT20 (SKBT20) 850 Amp 12 Volt AGM Power Cell Battery batteries. I had to go with these because of their size and space issues in my truck.
I contacted Shuriken to ask which battery charger they suggest to use, they recommended the Amazon.com: CTEK Multi US 7002 12V Battery Charger: Automotive
This is the isolator I've chosen, still haven't ordered, because I'm still trying to figure this all out, but, this should be fine, correct? The Install Bay IB500 500 Amp Battery Isolator and Relay | eBay
So, my first question is on hooking up the isolator. The isolator calls for an ignition wire, can that be my remote turn on wire that goes to the amp? From what I read, it's only giving a signal to the isolator to let it know to turn on, when the truck is on, which is what my remote wire going from my head unit to the amp.
Now running wires to everything. I'm pretty sure I got this, but can't seem to find any solid info on it. I have plenty of wire, and like going overkill, so overkill is what I want. I have one battery (Optima YellowTop) under the hood. I'll have six batteries wired together in the back. I'll take one or two runs of 1/0 from the battery under the hood positive, and go to the isolator. From the isolator, to the six batteries positive. From the six batteries positive to amp. My grounds, I want to run one or two 1/0 from the battery negative under the hood, to the battery negative on the six batteries in the back. Again, I know it's not necessary, but, I like overkill, I don't want any ground issues, every time I have a problem, it's always a ground issue, this way I don't have to worry about it.
Right?
Also, the batteries will be hooked up in parallel, so, can I hook up the charger to one of them, and it'll charge them all, or do I need to disconnect the batteries, and charge them all one at a time?
Any other info I'll need before running my wires would be great.
Right?
