Help with my box....
  • 1
Freelander
I've got a basic design I want to use but from looking at the boxes that are built on here it seems like a little bit more needs to be done.
Click here for my basic design.
From what I've seen people like to use 45's in the corners. Does the box need any bracing or is that what the 45's are for? I'm also wanting to do a double baffle will that make the subs displacement less since its bring the sub out of the box a little bit?
If someone could take a look at the design and tweak it to make it better it would be appreciated. Also a sketchup of the box would be cool too if someone has some extra free time. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
no one has any input on anything I can do to make the box better?
If I had 45's in the corners is it going to change the tuning dramatically? What about bracing and double baffle?
I got all the wood cut and I'm going to try to build my 1st box using no screws at all since most here say its stronger.
I'll be posting a worklog of the build in a little bit after everything is done.
985
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
691
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
Freelander
Freelander
Jacksonville. FL
Freelander
    May 12, 2024
Brendon Jenness
    May 11, 2024
