Help with mt
2loud4u
Nothing to see here
Ok here is the story on it.
12" Mt 3 cubes @ 35hz 50 square inches of port area
Dual 1.4 ohms coils
Wired to the amp it reads 0.6 ohms.
2500D @ 0.6 Ohms
Voltage at speaker outs 50v
0db 50hz test tone
head unit turned up 3/4 of the way
Sub controll all the way up.
Voltage is a Steady 14.2v car on.
Just not getting loud at all.
50 hz test tone sounds some what loud but no wheres close to what it should be doin.
During songs the voltage at the speaker terminals is 20.2v max
Setting on 2500d
Gain set with 0db test tone
Intelli q set to 0
Hpf set to 30hz
low pass set to around 80hz
phase set to 0
12db slope
I am alittle upset I thought this thing would get loud but not even close.
even with the trunk open and play throw it up ect... the sub hardly moves and also very little air comes out the port.
No one can help me out?
I just went out and played little jhon throw it up and voltage at the speaker teminals did not go past 21v.
Maby I need to use a -3db test tone.
But I dont know.
Any suggestions are more then welcome
take a pic of the side of your amp the settings are set at right now
cant no camera
But settings
Gain set with 0db test tone 50Hz 50 volts
Intelli q set to 0
Hpf set to 30hz
phase set to 0
xover 12db
Gain set to master
also voltage does not drop under 14v
yeah.
Just set it with a -3db 50hz test tone and went for a drive.
Poped in 36 late night tip and it got loud!!
It shook my head so much I could not read the display on my deck woot woot it is ugly anyways lol
Checked it during late night tip and it was hitting around 38v on the speaker terminals.
So she has alittle room left to go for sure.
Tomorrow when it is light out I am going to let it rip and tune it buy ear.
The sub is still brand new reconed quad stiff so it will take alittle to break that baby in.
Getting better.
The polairty with a 9v battery how can I tell?
Take a 9v battery and put the positive wire to the sub onto the positive terminal of the battery and then the negative wire to the negative terminal. The sub should move out when you do this. If it doesn't move (I'm pretty sure even an MT should move) then you may have them out of phase. After switching the polarity of one coil, try it again and see what happens. If it now moves out, you're good to go. If it moved out from the start, try setting your gain by ear instead of a dmm.
The only time I use a dmm is when I have to get two amps to put out the same power. I will set the first amp up by ear and then measure it with a dmm then I use the dmm to set the second amp up using the same load.
2loud4u
Nothing to see here
2loud4u
canada
2loud4u
