Help with mt
39v is 2500 watts
2500*.6=1500
sq rt of 1500 is 38.xxxx
I just set it at 1ohms cause it will never sit at 0.6 ohms
also it will put out alittle more then 2500w @ 0.6 ohms with a steady 14v
more like 2800-3000w
Right now it is getting some what loud.
-3DB test tones Ftw.
But still not enough output for me.
Changed a few setting on the amp
Gain set with -3db 50hz tone
Intelli q set to 1/4 up
12db slope
Hpf 30hz
lpf 80hz
Turned head unit up to 45/63
sub control all the way up
eq Flat
Loudness off
turned up the gain till the voltage reached 49v
Poped in some music and listed to the sub and it did not stress distort ect.....
took reading of the speaker voltage during music and it was peaking around 36-39v
Building alittle smaller box 2.5 cuft after displacement tune alittle higher maby 37-38hz 60-70 square inches of port area.
This is really on a temp system I have changed my goals and getting a crx.
2X15" Fully decked out BTL's amp(s) not sure yet.
Still not very happy with my 2500d so dont think I will get another.
Maby 2 kicker 2500.1's
You should be able to get loud with just the one amp!! I have my MT on a Kicker zx2500.1 right now and i can consistantly break 150, something is either wired wrong or amp just isnt working properly.
Well I think it was just a setting on the deck.
I changed it and started to play music and it was hitting really well.
Lots of fex, my back window, deck, trunk lid.
My buddy sat in it and got out after about 5 seconds.
Checked votage during music and it was around 38-44v
Mt was not distorting or stressing.
Still I think there is something wrong with the box maby?
3 cubes after displacement @ 35hz 50 square inches of port area.
Going to try alittle smaller box 2.5 cubes same port area maby 60 square inches and same tuning maby alittle higher. 37-38hz.
Could also just be me or my car dont know.
Time to put it on the tl and find out what is going on.
2loud4u
Nothing to see here
2loud4u
canada
2loud4u
BP1Fanatic
BP1Fanatic
