Help with lanzar manual
Ok thanks how to I intercept the wire from amp to battery with key operated red wire?
Look into the fuse guide of your car's manual. It should point out the radio fuse in which you can use an "add-a-circuit fuse adapter".
Is this correct?
Does the amp turn off when the car key is turned off (even though direct cable to battery?)
Thanks
carauser
CarAudio.com Recruit
carauser
france
slater
    Oct 4, 2025
    Oct 4, 2025
