help with installing an aftermarket radio to an 05' chevy equinox
usually I stick to Metra harnesses, what did that one cost?
you may need a different harness. there seems to be quite a few for this vehicle.. GMOS-07, GMRC-05
did your harness come with a speaker?
Well they asked me at the audio shop if I'd like to retain the door chime, and I told them no. So I have no idea what the problem is, we wired up everything correct and it just continues to do the same thing.
So the thing doesn't light up or anything either?
Im pretty sure you have the wrong harness. You're going to have to try the GMOS-07 or GMRC-05 or equivalent (little pricey).
OR, get a DMM and check your powers. I'm willing to be you dont have a full 12v on your ignition wire. you can manually run it from the ignition switch if you'd like
ok man what you need to do is tap a fuse that only works when the car is on. find the sunroof fuse(even if you dont have one its probably in there) and use that for your switched 12v(red wire) These cars use Class II data to turn on the radio, the non chime harness doesnt interpret Class II and provide a switched 12v so you have to tap a fuse that is switched. I had to do the same thing in my 01 alero and my 08 grand prix..
exactly
brandonmann
brandonmann
Brunswick, Georgia
THUNDERBIRD
