Thanks Mike, I'll go try that out right now since we have the same car and all...im pretty sure it was from the ground on the HU
The middle wire is really a grounding wire and not a REM wire.The nice ones, yes shielded, even has the REM wire in the middle, that I don't use.
nah, if it's the klarity kable knukonceptz says it a remote wire.The middle wire is really a grounding wire and not a REM wire.
Just tried running a dedicated ground from the - terminal to the chassis of the HU. No dice.From the rear battery and power cables.
They're running about one foot away from the amp from the LOC that is tapped into the rear speakersi still think it may be rca cables. they are running from the front of the car to the trunk, right?
It's grounded directly to the rear battery which is grounded directly to the hood battery with dual 0/1 awg Big 3.Where do you have the amp grounded?
oh. so how long are the cables?They're running about one foot away from the amp from the LOC that is tapped into the rear speakers
