lostdaytomorrow
I finally got a front stage in my car this past week.
I'm running a Kicker ZX850.2 and Boston PRO60's passive.
I'm using a David Navone LOC that is tapped into the rear speakers. This LOC can not be the cause of the whine because all of the wiring is the same from when I ran a sub amp off the LOC and there was no whine.
This is everything I have tried.
1. Thought it was induced by the crossovers being mounted up in the front under the dash with all the other electronics, so I uninstalled all of that and moved them to the trunk. Nothing different.
2. I tried each side at a time to see if it was both sides, it is both sides.
3. The whine increases with the RPM's. It is a very high pitch whine, but not very loud at low rpm's.
4. I have hooked up an iPod directly to the amp with RCA's and there didn't seem to be any whine that I could hear, so this made me think it was the RCA's. I went out and replaced the Knu RCA's with some Stinger RCA's. No difference.
5. Keep in mind the same exact LOC and RCA setup was used my for my old sub-stage and there was no whine issues.
6. There are two runs of 0/1 awg from the front battery to a G31 Yellowtop in the trunk. One + and one -. These runs are within about a foot of the 4 speaker-wire sets going from the mids and tweets to the trunk. This should not be a problem but there's no other choices for me.
7. The YT and all that wiring is in the left rear of the trunk and the crossovers and speaker and RCA's are on the other side of the trunk.
Someone please give me some ideas on what else to try... It might be the amp because I got it used for an amazing deal, but I wouldn't think so because the iPod seemed to work just fine without the engine whine which also means it can't be the speaker wires being next to the two runs of 0/1 awg either.
Thanks for helping me out.
