Help with determining RMS output .
AdamC
Hey guys I'm trying to determine the output on my brothers build . He's currently running 3 SKAR IX 10's on a 800 watt mono in a sealed enclosure . From everything I can gather off a volt meter , the final wiring impedance holds steady at just over 2.5 ohm . The amp is rated at 600rms at 2 ohm , but dyno's at 710 on a certified test at 2 ohm and uncertified at 808 2 ohm . Would I be safe to say each sub is getting at least 225 rms on the low end ?
I'm asking because the subs are low rms rated at 200 each ( " conservatively " ) . I really don't think he gives a **** however I'm an auto tech so I deal with electrical on a daily basis and I can't seem to figure out the formula for this one for a somewhat accurate measure .
yeah like darth said probably 150 each at most.. 1 better sub in nice ported box be better on that amp i'd bet..
That will give you VA, not RMS.
Based on the power factor at the time of the given clamp, VA can be as much as double that of RMS but VA will never be below RMS, always greater.
AdamC
AdamC
Indiana
THATpurpleKUSH
BP1Fanatic
BP1Fanatic
