Help With Build
Crownvicon28s
God 1st
Putting together a build for a friend of mine. He has a 95 caprice with about 13 cubes to work with before displacements. I could squeeze more room out of it if possible. He also has a Kicker 2500 amp. Im thinking 2 15's in a 4th order but not sure about brand/model of subs. Let me know what you guys would run?
What's the budget?
Not really sure on his budget, as least expensive to get decent subs in the power range. Should be too expensive with him only running 2.5k. Ill say 5-800. Thinking about 4 of the yard sale sa ultra 12's in a standard ported box. Not bad subs for 460 shipped. Lol.
Id do 3 12s or 2 15s in a 4th ported thur rear deck.. Did u see that flagstorm or whatever his name is impala on Caco? 2 zv4 12s or 15s in a 4th in a impala truck doing like 153 and when he had an at1400.1 on it still did like a 49.
Yeah I saw that. So far he wants to run the ultras. Just trying to keep all options open so the 4th is still in play.
2 15s in a 4th will be tight.
Tight?
Tight as in I don't see it fitting unless you can get about 3 more cubes.
Ah ok. Yeah he will have plenty of room. The guy he is referring to in post 7 with the impala has 2 15's in a fourth. CortezDTV on CACO also did a 4th , 2:1ratio, in a crown vic and my buddies trunk is even larger that both of these cars. The 13 cubes was also conservative. Space would not be a problem.
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
vegang
vegang
