help with bt on kenwood hu
treadburner
i have a kenwood ddx512 with nav and it works fine but when i got the blue tooth addaptor i had some problems
i know i plug in the gps to the bt but it has 4 pins im suppose to switch but the manual only shows 3
the bt modual is bt-200 i believe
also gps does not work when plugged in to the bt addaptor
tried putting the pins every different way possible and nothing worked
any help is appreciated
---------- Post added at 06:02 PM ---------- Previous post was at 06:02 PM ----------
also bought an ipod addaptor which also does not work
Are you using the half round "KAB"adapter with the BT? You have to use the same ports in the daisy chain. In other words the Nav has the KAB port you have to use the same port output from the bt200 to the KAB input on the DDX "not the 5L changer port" for it to work or only the device next to the unit will work.
i unplug the gps and plug it in the bt then plug the exact same plug as the gps but from the bt into the hu and neither work
but when it is just the gps it works
---------- Post added at 10:16 AM ---------- Previous post was at 10:15 AM ----------
im thinking it has something to do with the 4 switches that are suppose to be in different orders for each radio but the instructions only show 3
treadburner
treadburner
st louis, mo
bjude1
