MikeCole89
Can someone tell me what i should tune a box to i was thinking around 40hz(going for spl)..also can you tell me how much air space would need and how big i would have to make the port? dont know anything at all about making boxes so. would appreciate it thanks ill get the specs for the subs they are 2 DC 12" level 5
EDIT: ok i found the air space but how big should i make the port?
12"
Mounting Depth 8.25
Mounting Hole Diameter 11"
Motor Width 9.84"
Weight 78lbs
VC Diameter 3" Flat 8 layer
Magnet Weight 73lbs
Power Handling RMS/Peak 2000/4000
20,000 burst
Impedance D 1 or 2ohm
Sd 494.00 cm²
Suggested Ported 1.75³ ft
Suggested SPL Ported 2.75³ ft
12"
Mounting Depth 8.25
Motor Width 9.84"
Weight 78lbs
Magnet Weight 73lbs
20,000 burst
Sd 494.00 cm²
