Help with box for 4 15" csxs in a hatchback
SplChoice-
Weez.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif well im pulling out my backseat and these are the dimensions i have to work with ill be putting 4 15csxs in it with a memphis 4kw powering it at first then ill be strapping 2 of them eventually.. this is kinda the design that would have to go in there.
bolt it to the floorpan, grind the boltheads round. if and when you ever need to remove it, just drill out the bolts or grind off the boltheads. then you just need to figure out how to bolt the car down... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
all my amps are bolted to the floor of my car under the back seat, with stainless bolts bent over so they will have to be cut to be removed...
actually looking at it again it looks like it will have to be built in the car and therefore be unremovable! good call... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
thanks for telling me that..*gets bolt cutters* //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
SplChoice-
Weez.
SplChoice-
Oak Hills, CALI
oglejust
