help with box dimensions
Default 501x
alright so i am trying to build a ported box for my 1 DMX-15 with 2 circular ports. i have the volume, frequency, port diameter and port length for my box, but i cannot find anywhere to give me the dimensions for the box. every ported calculator i have tried is for slotted ports. help?
thanks
wow i almost forgot dims are:
volume: 2.95cuFT
Frequency: 42hz
number of ports: 2
port diameter: 4.02in
port length: 9.95in
vas: 1.607cuFT
qts: .413
xmax: 15m
qms 3.165
qes: .475
peak: 5000w
it sounds like you already have all the info you need. make a box that is the size of your total volume (including driver required vol, port displacement, sub displacement, and if you useing 3/4 material, add 1.5" to all three deminsions.) build a box that you can fit in your car that also matches the deminsions.
Default 501x
Default 501x
Seattle, WA
Trixter
