help with bandpass in 2001 focus trunk...please
ktraughb
it is a trunk focus. my most recent box was a pretty run of the mill 4.25 cu ft box, tuned right around 40 Hz. it did fairly well for spl, and still had some musical quality. what i am thinking of doing now is a type of bandpass enclosure. i understand sq is at a loss for most bandpasses (not all) but i also understand that if done correctly they can be much more efficient than a simple slot ported enclosure.
first off, has anyone attempted to build a bandpass in a similar trunk, and second off was it a fourth or sixth order? i simply dont think ill have the room for a sixth order, but some general plans i have made for a fourth order would work. overall usable external space is about 8 cubic feet. the one i have designed is about 6 total after displacement.
does anyone have any pointers whatsoever on designing a bandpass as far as chamber sizes (not specific obviously but a generalization of comparison from sealed to ported chamber). the subs will most likely be a pair of p3s, type rs, or some ma audio hks.
i dont have the t/s handy for any of these so im simply looking for some general rules as of right now. any help is appreciated ahead of time. also, i am not opposed to porting into the cab through seat opening, and i have already cut a ten inch port opening through my rear deck for an older box. so it is usable as well.
Bandpass boxes are tricky to get right. They are also limited in bandwidth, but are more efficient. Unless you are going for high output and don't care much about sound quality I would steer away from them. There are a few programs to help you design a box, such as Unibox(free, needs microsoft office), WinISD(free, buggy, complicated), and Eminence speaker Designer/BassBox Pro(not free, but my favorite).
ktraughb
ktraughb
Louisville, ky
ktraughb
michigan born
    May 14, 2026
michigan born
    May 14, 2026
