Help with an install (03 sante fe)
therikoxide
16
usa
2003 Hyundai Sante Fe
I picked up two sets of Kenwood KFC-1682ie's and when I got my door panel off, I noticed the stock speakers have an adapter with four wires (white, black, brown, yellow) and the new speakers only have two wires (blue/gray, gray).
I cut the adapter off the old speaker and attached the two white wires to the blue/gray and one of the black wires to the gray wire, but it is not loud at all compared to my stock speaker.
How do I install this?
UPDATE: Photos
Run new wire? You mean completely from the deck? I am a completely ignorant about this stuff, I was told it was basically plug-n-play.
Yeah, the original speaker had tweeters I could take out and they were individually wired. The new kenwoods have the tweeters wired inline. So, im not sure what to do with the other set of white/black. Either it has bass or treble it seems, and if I try running the white wires to the blue/gray it gets really soft.
white +
brown -
connect gray to white and gray/black to brown. Me sure to solder or crimp the connection, not just tape and wrap.
white +
brown -
I have blue/grey for positive and gray for negative.
So attach the blue/grey to brown and grey to white, what about the yellow and black?
if blue/grey is positive connect it to white. and then gray to brown. (double check, tho. usually the solid color is + and the striped is -. the positive side is the wider terminal on the speaker while the negative is the skinny one)
the other wires are for the stock woofer. just tape'em off.
therikoxide
therikoxide
usa
x1le
