Help with amp
If you're going for 2500wrms @ 2 ohms for $300 you need to be looking in the classifieds. I wouldn't buy anything with Boss on the box.
What are some classy brands? I know nothing about amps so I need all the help and information I can get.
Hifonics is gonna get you close but the 2 ohm thing is gonna kill you for the $300. 1 ohm wouldn't be so bad, but 2 is not as easy.
What does 2 ohm and 1 ohm mean? The sub I have is a double voice coil 4 ohm so wouldnt i have to run it off of a 4 ohm amp?
A dual 4 ohm speaker you can wire it to either 2 ohm or a 8 ohm load. The 2 ohm load you have to wire to 2 voice coils in parallel to the amplifier terminals, and for a 8 ohm load you need to wire the 2 voice coils in series to the amplifier. Ohm is the measurement for electrical impedance or electrical resistance.
Ok so basically I need to find an amp with a high wattage at 2 ohms?
KickerSolo
KickerSolo
Jackson, Ms
jpexpc
AJ (ACE)
    Jun 28, 2026
