Help with amp going into protect
buckeyes#1
Digital designs M4 amp played fine when i purchased . hooked everything back up amp was in protect soon as power was turned on , my 4 channel amp running off same electrical no issues , i unhooked rca's speakers, and remote jumper power to remote still went into protect , i sent the amp in for repair , kevin messaged me yesterday with a picture nothing wrong with the amp with video of it playing fine ? wtf is wrong here 2 grounds to chassis voltage was at 12.7 (same voltage he had testing the amp) what do i need to look into with my electrical causing the protect any ideas and or thoughts ? any suggestions thanks btw 3 xs power 3400 agm 0 gauge wire all fuses check ok with volt meter
Some amps are pretty sensitive about grounding properly and securely. Also will happen if the voltage is too low.
Also check for corrosion in your power/ground wire. I've seen amps go into protect when that happens too.
Just confusing had amp mounted to the sub box for years no issues , redo the setup move the amp now I have problems , I think I'll check grounds and bolt amp to a piece of wood then to the floor
buckeyes#1
buckeyes#1
p-town
Boomin_tahoe
NorthFramingham
    Jun 30, 2026
