Help with amp and power plz
  • 2
maxtiger37
I bought a 3400-watt boss amp hooked and it up ground is good power is good remote wire The boss logo light only lights up halfway and it flickers when I play the normal stereo with the car on. what's wrong? I have sent the amp back and it was replaced. does the battery not have enough power to feed to the amp? Thanks. The car is a chevy cobalt 2009.
first suspect is the ground connection.  you need the ground wire securely bolted to the frame or chassis.  that location should be bare metal with a proper ring terminal on the wire.
I have it grounded where the battery is grounded should that be sufficient? Thanks.
So I regrounded the ground wire to the frame but that wasn't the problem. I found out the remote wire to the amp needs at least 9 volts for the amp to work. So I tapped into the fuse box. Thanks for your time @keep_hope_alive
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
516
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
326
maxtiger37
maxtiger37
maxtiger37
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
