Help with amp and power plz
maxtiger37
I bought a 3400-watt boss amp hooked and it up ground is good power is good remote wire The boss logo light only lights up halfway and it flickers when I play the normal stereo with the car on. what's wrong? I have sent the amp back and it was replaced. does the battery not have enough power to feed to the amp? Thanks. The car is a chevy cobalt 2009.
first suspect is the ground connection.  you need the ground wire securely bolted to the frame or chassis.  that location should be bare metal with a proper ring terminal on the wire.
I have it grounded where the battery is grounded should that be sufficient? Thanks.
So I regrounded the ground wire to the frame but that wasn't the problem. I found out the remote wire to the amp needs at least 9 volts for the amp to work. So I tapped into the fuse box. Thanks for your time @keep_hope_alive
maxtiger37
maxtiger37
maxtiger37
