help with aero ports...
blackbonnie
The Revolution
im getting my design down for my new box that will run a 18" nightshade. im gonna be using aero ports for this build and this is the first time ive ever used them.
my box will be 5ft^3 @ 32hz after displacements
i think i will need (2) 6" aero's at 11.76" a piece to achieve a 32hz tuning.
1: is the tuning correct?
2: do i have the correct port area?
(the rule of thumb is usually 12in^2 per 1ft^3 of box....but i have heard that you dont need as much port area with aero's) with this i have 56.52 in^2 of port area i believe.
3: any things i should do or change about my design?
no they need to be 25" long
4 4" is 23"
your gonna need 3 4" at the full 17" to do 32hz which is 37 square inches of port area a little less than 8 square inches per cube, so you should be fine. oh yeh and 12-16 square inches per cube is ofr slot ports, about 8 square inches for aeros
can you explain a bit on how you figured that out.
i didnt know the rule of thumb for aero's. so it is 8 in^2 per 1 ft^3?
so your saying i need 3 4" aero's and each one needs to be 17" long?
can you elaborate a little more on how you figured that out
if thats what u want to do i think your gonna have to get xtra 6" tube and a coupler to make them that long. if that even works. thrilleraudio.com has coupler rings and tubes and flares and the full kit
well psp's kits are 17" long, and i could just cut those down right?
Your ports need to be 26.38" long each. Just buy the PSP flares & couplers and use some 6" thinwall pvc from your local hardware store for your center sections.
blackbonnie
The Revolution
blackbonnie
Grand Rapids, MI
blackbonnie
