rodneypierce
- Thread Starter
- #31
No... I know the polarity of each driver. They are all regular or standard polarity EXCEPT the drivers side midrange.then you need to verify proper polarity on every driver. having different left and right means you have polarity mixed up.
so reverse polarity on both - so you have the same focus but you blend well. right now, you dont know what actual phase is.
it is important that you use speaker wire that has identification for polarity, and that you are consistent with polarity. i use red and black heat shrink and/or electrical tape to label speaker wires for clear identification.
I went through and isolated each speaker after I did my TA, then switched each individual speakers polarity to see if it sounded better/centered the sound better, or if it scattered it again. If it sounded better, I left it, if it scattered it, I put the polarity back to normal. Then I switched the set polarity on each PAIR of speakers to test the same, if it didnt sound better, switched the PAIR back to how it was. They are all on standard ( + to +, - to -) polarity EXCEPT for the drivers side midrange. Its reversed.
