Help with 1st box
its weird.... bc the front is supposed to be 14.5"h x 15.5"l, but the sub is 15x15 lol its not goin to fit i cut it an tryed //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
being that this is your 1st box....
the front FACE is 14.5 NOT including the top and bottom pieces which are 3/4" + 3/4" =1.5". so top to bottom is a total of 16", which will fit 15" subs. Most 15" subs require a cutout of 14" which would leave you w/ 1/4" above & below the cutouts.
that's if you mount the sub traditionally, but if you turn the sub just a bit, then you'll be able to keep all the screws on the face piece. if you would to drill on the top or bottom piece, then you would most likely split the wood.
here's a pic of an example... notice that the sub is tilted a bit... the top hole is not in the middle on top.
haunther
Banned
haunther
Melbourne FL
haunther
vegang
vegang
