help wiring zx750.1 two two subs
xDeth7
I bought the 750.1, was told perfect amp for my two 12" cvr's.(4 ohm daul voice coil). All schematics I'm seeing are with the subs wired four or one ohm. Is there no way to wire these at two ohm with this mono amp? Or is the amp a little tougher than it claims and can take a 1 ohm load and run hot, or would it kill it.. Help me asap working on this now... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif THANX
Some amps say not two or one ohm stable when they really can hold it, if you keep the gain low and watch it a bit. Can the zx750.1 do one ohm at all?????? Or should I hook it up and see if it overheats at low settings... HELP ME!!!! I'd hate to have to wire these in four ohms and lose like 300w rms.. THANX
;2837699']Meh' date=' I wouldn't go beyond what the amp's are rated, just to be safe. I'd have gone with Kicker amps, myself, if it wasn't for their impedancy load handling.[/quote']
Runs both in 1 ohm load and vibrates other cars in parking lot. Seems very stable at 1 ohm and is producing tons of power. Sounds like something alive trying to beat its way out of my trunk.. crazy bass.......But thanks for info just the same.
xDeth7
xDeth7
Saint Louis, MO
xDeth7
