Help wiring up 2 subs to a mono amp
CplCuddles
Certified Meme Warrior
I'm not super knowledgeable with wiring and such, so I need help. I am getting 2 12" Sundown Zv4s, I was going to power them with a SAZ-5000D, but I'm not sure how to wire them up. The 5000d does 1400w@4, 2500w@2, and 5000w@1. Now my question is, how is the power distributed and is there a way to run them at 1 ohm so each sub sees about 2500w? If not, should I get more than one amp or something? the Zv4s only come in D-1 and D-2. Thanks!
a dual 1 ohm voice coil sub wired in series would be a 2 ohm load. Then each sub in parallel would be a 1 ohm load on the amp.
Two D1s can be wired at .25 ohm, 1 ohm, or 4 ohm on a monoblock. Two D2s can be wired at .5 ohm, 2 ohm or 8 ohm.
Alright, I'll just get the D1, Thanks.
CplCuddles
CplCuddles
Topeka, KS
CplCuddles
