Help Wiring New Amplifier
Its not that i couldnt get a monoblock just the fact that i couldnt wire it at 1 ohm without a dual battery set up which i dont want.
whoever told you that you cant wire an amp to 1 ohm without a dual battery is a jackass.
I suggest wiring the subs @ 2 ohm stereo on half the amp and use the other half to power the front speakers.
http://www.maxxsonics.net/manuals/hifonics/pdfs/HifonicsZeusZRXAmplifierManual.pdf
In the manual on page four it says "A MONO signal source is required to bridge channel pair 3/4. Im not sure if this is correct for what i am trying to do because it is under the section that explains how to configure it as a 2 or 3 channel system. Could you clear this up and once again is it even possible to do this with alpine swr 12d2s?
Like i said before "you would need two splitters, each single female to 2 male. Use the left side of your sub out for ch1/2, then right for ch3/4, or vice versa." Each channel would be getting a "mono" source. Yes you can do it with those subs. Also, most mono amps are class d, which are more efficient than class ab amps. Not sure why you'd think you need a dual battery set up to run a mono amp, but not a 4 channel class ab amp.
Alright i got it that makes sense. And i only needed the dual battery if i ran it at 1 ohm. (The guy was a car audio specialist but im pretty sure he was just being safe) I agree that i should of got a monoblock amp but i didnt so i need to make this work. Thanks for the help im glad that i didnt waste 250 bucks!
Hmmmmmm someone lied to you... This 2k class ab amp will require a much more beefier electric then a 2k class d amp... This thing is going to **** juice like nobodys business.
GKella
GKella
Colorado
disturbed471985
