Help! Wiring 2 Sundown SAZ-3000s to 2 subs.
AcidikBass20
Bass Addict
Subs are wired together at 2 ohms. I have 2 sundowns running, 1 amp for each. The subs are both seeing 2 ohms and putting out 1600 to each sub. Which output terminal do I put the speaker wire in. Left or right. It says for 1 sub its right, 2 its left, but the amps are not strapped. Help?!?!
Not Strapped! Each running 1 sub individually!
each running 2 ohm, 1600w, to an Earthquake DBXi-12d.
I think he is asking which terminals on the amp to put the wires in. He has them wired correctly at the sub, but since there are two +s and -s on the amp it is confusing him.
Excactly! Thank you! So are they done right?
Also, I am gettin a nice whine from the amps while its running. the lower the music and quieter the whine. I think its the amps because I turn the car off and the whine still goes until the automatic shut off kicks on and all the amps turn off. ideas?
AcidikBass20
Bass Addict
AcidikBass20
South Bend, IN
GMCJimmyslt2000
