Help understanding Class D amps
its made to work like that just use 4 lengths of wire for + and 4 links for - every where it goes into/from a terminal start a new link dont try to use one continuous length
ok so lemme clarify this
starting at the amp [+]-----+ terminal on the sub-------+ terminal on the same sub-----+ terminal on 2nd sub ------- + terminal on 2nd sub??
ok i quit.....
the above isnt right i dont think.
to me the diagram looks like you are attaching the wires together
Each line indicates a new wire, you can fit more than one wire in each speaker terminal.
In the end you should have 2 wires going your amp.
EDIT: I forgot to fill in the end circles... bottom circle is negative to the amp, top is positive.
DePratt
learning n00b
DePratt
Illinois
DePratt
