Help tuning sub/ amp
Umm... if you have set your low pass filter and if your gains are set, there is nothing left to tune on the amp.
I think you're confused with the tuning frequency of an enclosure. This is done with non-sealed enclosures and done during the design phase.
I'm trying to set the gains on the amp. I did the formula and it needs to put out like 39 volts. When I download a test tone I want to use -3db but don't know what hz to use?
89montero
89montero
Seattle, WA
Immacomputer
michigan born
    May 14, 2026
michigan born
    May 14, 2026
