help to properly power my HU
Antics
I have a Clarion DXZ785USB (6volt pre amp outlets.)
I have all the necessary wires spliced and connected EXCEPT I have 2 yellow wires left on the HU harness. They are both connected to fuses
Yellow Wire (3A) : Bus Power Lead (connect directly to battery)
Yellow Wire (15A) : Memory Back-up Lead (connect directly to battery)
I only have 1 wire left on the aftermarket harness
Yellow Wire : 12 Volt Batt/Memory (12V Battery/Constant)
how would I go about connecting them? wire both from the HU to the battery?
if I wire from the battery to the HU what type/size wire should I use? and should I connect both those wires from the clarion harness to the 1 wire coming from the battery? Ignoring the yellow wire from the aftermarket harness?
also same question goes for the ground, what type of wire and should I just run it to the chassis of the floor? I have a 92 mitsubishi 3000gt where it's required to run your own ground (to the radio chassis)
Thanks I'm a noob //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
connect all three yellow wires together and you should be fine and just find something that connects to the chassis to get your ground just make sure you sand off any paint to get a good connection
even if the HU instructions says to connect to the battery it'll still work %100 that way?
Only issue could be without using the ignition power, your battery could run down.
ooh, I really don't want that to happen since I'll be using the stock battery & alt. So what's the best way to wire it? what type/size gauge wire should I use?
thanks
Antics
Antics
Rancho Cucamonga, CA
Antics
