HELP! This is making NO sense!
Torquem
I am going to have an enclosure built tomorrow and the information that I have on the subwoofer is making absolutely no sense to me. I need someone that really knows what they are talking about to interject. I bought an eclipse SW8010 and the way they present the info is confusing. Rather than giving figures like "displacement" and "net internal volume" they simply give this info -
recommended internal enclosure volume - 2 cuft
tuning frequency - 33 hz
internal height - 18.5
internal width - 12.5
internal depth - 20
port opening area - 2"x12.5" (25 squared)
Port length - 28.5
I'm used to seeing sub requirements in a completely different way and I cannot make sense of it. I need to change the shape of the enclosure and retain the internal volume and tuning frequency but I am unable to extrapolate anything from the info above.
If it helps the TS parameters are
nominal impedance - 4 ohms
Voice coil DCR - 3.3 ohms
FS - 21hz
Qms - 5.25
Qes - 0.39
Qts - 0.36
Vas - 28 L
MMS - 356g
Xmax - 22mm
Dia/Sd - 347 cm2
BL/No - 20 Tm
1 watt SPL - 86 dB
well it says the sub wants an internal volume of 2 cubic feet for a ported box with a port that is 2" tall x 12.5" wide for 25 sq'in of port and it needs to be 28 inches long... the box is INTERNALLY 18.5 tall, 12.5 wide, and depth of 20... now thats internal... I guess you will have to make an L shaped port if its going to be 28" long as well.
Torquem
Torquem
Apex, NC
CRXBMPN
Mike Mccabe
