help! System not hitting hard at all.
Check you power wire...... Make sure you haven't burnt the wires.
( it usually burns at the fuse in the front on either or both sides. )
if you squeeze the wire where it goes in the fuse & out the fuse and you hear a crunchy sound... You need to cut about 3 inches - 4 inches from the side(s) that are burnt.
... Reconnect, and you will have full power again. ( make sure your amp & hu are set, cause if everything is turned down... You wouldn't be able to tell if that was the problem... Which i do believe it is )
That I will check and report back when I get can pull my car in the garage. It's cold out and I'm not at home. However, if I did burn the wires wouldn't it cause a lack of power to both amps, because I don't see a difference in output in the JL.
imo send the candence back or sell it and save up and buy a real sub an use that jl amp on it until you can afford to buy a decent amp like buy a dc level 4 15 or 12 what ever and then buy a sundown saz 1500d or if on a budget a audiopipe 1800d
Monday I'm going to call woofers and ask for a return number. I emailed them about returning it and they haven't emailed back..
Any recommendations on a DMM? I really don't want to spend too much.
Checked that power wire, it crunches. Would it do that if it were cold, too, because it had been sitting outside for almost twelve hours and there was a thin ice on the windows.
My computer's still not letting me go to the fourth page, and when I'm not logged in, it says there's only three pages?
Any more help with the Cadence guys?
wannabang
wannabang
43147, Ohio
wannabang
