- Thread Starter
- #46
That I will check and report back when I get can pull my car in the garage. It's cold out and I'm not at home. However, if I did burn the wires wouldn't it cause a lack of power to both amps, because I don't see a difference in output in the JL.Check you power wire...... Make sure you haven't burnt the wires.
( it usually burns at the fuse in the front on either or both sides. )
if you squeeze the wire where it goes in the fuse & out the fuse and you hear a crunchy sound... You need to cut about 3 inches - 4 inches from the side(s) that are burnt.
... Reconnect, and you will have full power again. ( make sure your amp & hu are set, cause if everything is turned down... You wouldn't be able to tell if that was the problem... Which i do believe it is )
Monday I'm going to call woofers and ask for a return number. I emailed them about returning it and they haven't emailed back..imo send the candence back or sell it and save up and buy a real sub an use that jl amp on it until you can afford to buy a decent amp like buy a dc level 4 15 or 12 what ever and then buy a sundown saz 1500d or if on a budget a audiopipe 1800d
