Help sub won't hit
Right they were empty this converter i have changes them to RCA im using high line imputs on a low line signal coming from my rovers amp
And thats where your problem lies. Dont know much about it. But i dont use those and my stuff works. Your stock amp should have nothing to do with it.
Yep i used the RCA converter on the stock lines and now it works! its weird it only works with one RCA in. i have to send my rovers amp to the left side for the sub to start working. are my wires still not wired correctly?
No for some reason everyones music will start with just 1.Its a specific one but I dont know the science behind it. Your all good..//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
if it works with only one rca connected you have the polarity of the connection at the factory sub wire out of phase. reverse one input side of the loc and that should fix the problem.
ninjaff21
ninjaff21
little rock ar
CrossoverOre
